4hp22 into e39???
  • Dj Buttchug
    • Jun 2010
    • 7682
    4hp22 into e39???
    This is a stupid question.
    1997 528i m52b28. blown trans. Will a 4hp22 from an e30 325i work?
    im thinking it wont but the g260 is run behind m5x alot. why would it not work?
    transmission control electronics?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
  • TheTacoMan
    • Nov 2011
    • 2308
    Why not?
    There really isnt any electronics linked to ecu in an e30 i believe
      Originally posted by TheTacoMan
      Why not?
      True, but he isn't putting the transmission in an E30.I don't know if a 97 E39 has an electrically controlled transmission. If there's a cable connection to the transmission, that would be a clue.
      • James Crivellone
        Head Janitor
        • 6305
        I think those used the A4S310R, really common and really cheap if you find a pick n pull.
        While the 4H22P would bolt up it would sit at a weird angle, and you'd need to custom fab the driveshaft, linkages, etc.
        Not worth it.
