So I finally replaced my broken selector rod and got back on track with replacing my flex disc/csb. After getting the bolts that hold down the transmission flange, I torqued down the bolts that were pointing in the direction of the transmission (front). I started turning the driveshaft and it seems that my bolts are too long. just by a hair. They keep grazing some points of the transmission. Not sure if I put the flex disc in the right way or the bolts that came with the disc are too long.
And when putting the bolts in is it bolt>guibo>trans/driveshaft flange>nut
