86 325E using a 91 325 CI Driveshaft
  • Smrtpunk
    • Sep 2011
    • 95
    Is it possible? If so what is involved. I think my U joint on the E is bad and I would like to swap the whole unit if possible.
    Thanks,
    Ian
    • 37834
    If both are 5 speed cars it will work.
    You'll need to change your center support bearing though since early and late model are different.
    Grover Beach, California
    BimmerHeads.com
    • Smrtpunk
      • Sep 2011
      • 95
      Excellent! I read somewhere that the output shaft on the I Trans is different then the E will this affect the setup?
      When I pull the driveshaft from the I car should I order a new CSB for an E car? I'm guessing re-using the old CSB would be a bad idea.
      Thanks for sharing your wisdom!
        • 37834
        The 87 325e had the larger flange during some months of production but the majority of 325e cars use the small flange just like the 325i.
        I'd recommend buying a new CSB and guibo if they're in bad shape. Go with Febi brand and not a cheapo.
        BimmerHeads.com
