Difference in e vs i abs half shafts?
  • wodcutr
    • Apr 2009
    • 2193
    I was doing a little research on ix rear half shafts and realoem PN's are the same for all e half shafts with abs but all i vehicles half shafts have a different PN. My question is what are the differences on the two abs half shafts and are they both interchangeable with each other? I always thought that any abs half shaft for an e30 could be swapped in for another and the only difference was with the non abs ones. Skool me boys!
    The difference between porcupines and BMWs is that porcupines have the pricks on the outside!
  • TobyB
    • 5296
    I thought as you did- in fact, the non- ABS e I took apart didn't have the holes
    drilled for the sensors, but DID have the sensor rings on the shafts!
    dunno!
    t
