5 speed swap quetion
  • isamemon
    • Jan 2009
    • 257
    yes I did spend time on the search..maybe did it wrong
    gonna help a friend with a 5 speed swap into a 325.
    1) Provided all parts are on hand, it seems like this is a one day shot...true ?
    Steve is only missing two things now......
    2) we have a pedal assy form a 318, will it work ?
    3) he wants to switch the diff at the same time...is there a chart someplace that will say what cars had what diff ratio's in them. ( and if lsd's) he drives past lots of pay-n-pull
    He does a sheep load of driving in wash, or, ca and arizonia ( short haul driver) so he can chase his parts, just does not have time to crawl under every car in every wrecking yard to find the lsd or ratio he wants
    thanks
  • kronus
    • Apr 2008
    • 13032
    It could be a day with two people, but you always forget stuff.
    318 pedals will work.
    There are lists out there, search a little. All e30 iS models came with LSDs, mostly 3.73 in manual iS, 4.10 in auto iS, and 2.93 in es. You'll probably want a 3.73...
    cars beep boop
    • deeze30
      • May 2013
      • 298
      No mean to hijack to the OP but it should also help out both of us because i'm in the same boat as him but what is the length of a m20 driveshaft? Reason I ask is because I wasn't sure if I pulled the right driveshaft at pick n pull the other day... I know stupid I didn't check -_- it came off a 90 325i. And another thing can I install the pedal assembly with clutch and new brake pedal now just for standby but obviously not attached to anything except brake pedals of course while I wait to get a day off to do the swap?
      • deeze30
        • May 2013
        • 298
        Anyone? Bump
        • isamemon
          • Jan 2009
          • 257
          im not so sure about that...in my years I have pulled apart two 318is that did not have lsd's, both 91's
          and of course my ic is not a "is' and it does not have a lsd
          of course they could have been switched out by others before they got to me
          and my 91 318ic has a a 4.10 in it, was that way when I got it
          • Wanganstyle
            • 2828
            Not all is cars have lsd; many many do not.
            Sent from my GT-N7100 using Tapatalk 2
              • 34839
              Your pedals need to match early or late model..
