can I change the CSB bearing without dropping the exhaust?
  • bastianshaw
    • Jan 2007
    • 2210
    i doubt it but wanted to see if anyone knew a trick, if i do have to drop the exhaust can i do it from the cat back?
    i hate dropping the exhaust if u havent figured that
  • Balleristic31
    • Aug 2009
    • 4198
    Yes you can. It just makes things much tighter
    -NICK
    • Dj Buttchug
      • Jun 2010
      • 7688
      this is gonna be a bit hard considering you have to press the new bearing onto the driveshaft. You need to pull the whole front piece of the DS out
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Silverdogz
        • Aug 2012
        • 168
        No. It really makes things a big hassle that is already hard enough. Besides you could use the opportunity to clean or paint the exhaust.
        so true.. never let them know where you live..I almost ended up in jail when I was raping young women on craigslist
        • bastianshaw
          • Jan 2007
          • 2210
          just lowed exhaust in rear didnt undo the down pipes pressed the CSB on w a hammer and dowel
