How to Improve Shifter Feel
  • 6SPD
    • Feb 2013
    • 243
    I've recently installed a Z3 1.9 shifter in my E30 and am rather enjoying it over the original 87 ETA shifter. Installing it, it had a great shift feel when the tough rubber gasket (that seals the shifter from under the car) wasn't there. It was really nice and mechanical, tons of feel, very notchy. After putting it all together with the gasket installed the feel became more muffled and it was harder to get into gear, I have to use a bit of force to get the shifter into each gate. With the previous shifter it would just slip right in fairly easy.
    My question is what can be done to improve the shift feel to a more mechanical feel, like it was without the gasket. Could it be that the gasket is meant to be aligned a certain way, an orientation where it has more give from being worn over time?
    The previous owner had replaced most of the shifter components during his recent ownership with what I believe to be stock OEM parts.
    Thanks in advance!
    À la folie
  • DIIRTY-30
    • 1665
    My short shifter feels exactly as described, unfortunately my PO installed it too so I haven't a clue if he put in a new gasket. It's slowly made me not like having the short shifter period, I already have someone willing to swap their stock shifter with mine because of it. My 1st gear is a PIA to get into the gate, everything else doesn't give me much of a problem. In 2nd sometimes if you leave your hand on it makes a clicking/ticking sound that gets louded as the RPMs wind up as if its hitting the bell housing (i think). Would be cool to solve and square the issue away.
    Sub'd for an answer.
    BLUE NOSE - M62 SWAP
    THE E30 + 1 BUILD
    • 6SPD
      • Feb 2013
      • 243
      Glad to hear I am not alone in this issue.
      À la folie
      • jclar
        • 265
        Which gasket are you guys talking about?
        '86 325es M50
        • Quadrajet
          • Jul 2008
          • 1278
          Have you guys checked to see if your shift rods have been making contact with the dampener ring of the transmission?
          I ask as I helped another guy do a shifter swap on an early E30. I had to bend the shift rod to clear his dampener ring. Something my M42 car doesn't have.
          • 6SPD
            • Feb 2013
            • 243
            The circular rubber piece that that joins the shifter to the body, above the ball joint. It's the barrier between under the car and the cabin.
            À la folie
            • serdar255
              • Feb 2013
              • 395
              Heavy shift knob and heavy dssr
              image (10) by serdar.gurhan, on Flickr
              PM me for custom shift knobs and stickers!
              Originally posted by marshallnoise
              You ain't done working on a car unless you are bleeding.
              • 6SPD
                • Feb 2013
                • 243
                Already running a ZHP knob. Definitely looking to get a UUC DSSR later in August when I get back to my car.
                À la folie
                • reelizmpro
                  • 9556
                  Amen to that. I have Z3 1.9 lever, custom DSSR, new selector joint, cup and UUC weighted knob. The throws are short and precise without too much notchiness.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • Bearmw
                    • 1323
                    Got the UUC 187 dssr and ultimate shifter with a ZHP knob on a 260/6 and it feels real good. Not cheap but good.
                    That said there are budget ways to improve such as a heavy knob, solder wrapped arm, and derlin bushings that help a lot.
