so i have installed the new selector shaft seal, detent spring seal, and the output shaft seal. I am at the point of installing the output flange and i read to use locktite 270 on the splines and back of the nut. could i just use locktite 271 instead? they both are high strength and the purpose of it is to seal oil from leaching around the splines and out- so i see no reason why i cant do this. i just want your opinion on this as i would hate to re-do it. (the 271 is already in my possession, so id rather use it than have to go buy some new stuff) i also read that bmw recommended locktite 242 for new trans? or should i not trust that? the 242 is a medium strength locktite.
also, the same for the input shaft seal. should i be using a sealer too? like the 242 or the 271? (both i already have) i read to use locktite 573 due to the slow cure time, but is it needed? or can i just use what i have along with a high strength RTV?
