These had 17mm EXTERNAL wrenching oil plugs. If the label is green, use Redline MT90. If the label is red, use Redline D4 ATF. If there was no label, the gearbox will have 17mm INTERNAL wrench oil plugs, and should use Redline MTL GL-4 70W-80.
Thanks
R.I.P 07/01/09 - 04/23/10 :(
