What happened??? (Shifter moved forward)
  • lambo
    Captain Scene Points
    • 10953
    Hey r3v,
    Something weird happened today... It was wet outside so I took a corner a little sideways, I didn't hit anything out of the ordinary however I hit a bump in the road somewhat quickly, nothing outrageous though. However, after that bump it seemed like my shifter moved forward and with it the whole shift pattern, obviously. Before this my shifter never hit my center console and now it does in 1st, 3rd and 5th.
    when I got home I checked my tranny mounts and motor mounts and they all looked fine. The motor mounts a solid condor ones and the tranny ones are only a year and a half old.
    What gives??
    Thanks for any help!
  • mr.vang
    • 4371
    Check your tranny brace
    • lambo
      • 10953
      It looks right... I don't see any cracks and it doesn't look bent or anything. Could it have slid forward or something?
      • mr.vang
        • 4371
        Yup, see if the nuts are tight
        Sent from my Nexus 4 using Tapatalk 4 Beta
        • freeride53
          • 11972
          lol #COprobz
          1983 Peugeot 505 STI
          1992 Volvo 240 Wagon
          • lambo
            • 10953
            They both seemed tight. If it were to have slid forward, what would the proper procedure to get it back into place be?
            • ak-
              • 12422
              Your trans mounts didn't sheer, manipulate or anything?
              1991 325iS turbo
              • lambo
                • 10953
                Doesn't look like it...
                Here are some pictars:
                Passenger side mount.
                Driver side mount.
                Location of the driver side brace mount bolt.
                Both mounts.
                Here you can see the shifter isn't concentric with the hole in the transmission tunnel.
                • LJ851
                  • 7919
                  Looks like your shift shaft is about to break in two. Check the angle of the pin in relation to the shaft, should be 90 degrees and i think i see a crack.
                  What did you do to that thing? You been workin out?
                  Lorin
                  The M30 is God's engine.
                  • lambo
                    • 10953
                    Holy shit... no kidding. I didn't see that before, I think the flash emphasizes it.
                    • Poorboyz
                      • May 2012
                      • 2117
                      Did the ears break off where the bitch clip mounts to the transmission causing the whole shifter carrier to move forward?
                      Sent from my Galaxy Nexus using Tapatalk 2
                      Rebuilding since 07/06/2016
                      Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                      Poorboyz Feedback Thread
                      • TimbyMaTombo
                        • Jul 2012
                        • 413
                        Had this happen to a friend's car. The shifter kept moving forward and he couldn't get into R, 1, 3, or 5, and eventually, his shift rod snapped. Looks like that's what happening to yours. According to my friend "everyday is a race" so he mustn't have been too nice to it. Maybe you need a DSSR...
                        • lambo
                          • 10953
                          I've done my fair share of hard 2nd-to-3rd shifts but other than that I'm not hard on it...I don't think.
                          Did anything else get damaged?
                          • LJ851
                            • 7919
                            Originally posted by lambo
                            ... I'm not hard on it...I don't think.
                            It's the PO's fault.
                            Lorin
                            • lambo
                              • 10953
                              Assuming all my mounts and braces stayed in place, would the selector rod bending be the sole cause of my movement in shifter? Now that I think about it, I was getting tail happy in 2nd gear and would have shifted, probably decently hard, into 3rd and that must be when it all happened.
