Do Diff Carrier Bearings Ever Wear Out?
  • redlightpete
    • Mar 2012
    • 266
    My 320k mi diff is getting pretty loud, and from what I've read, it sounds like the pinion bearings. If I take the diff apart and only the pinion bearings look bad, would it be crazy to reuse the carrier bearings? Do the carrier bearings ever wear out? I'd rather not disturb any more parts of the diff than I have to.
  • Wanganstyle
    • 2828
    Replace all 4 bearings with the races if you are going to attempt it at all; obviously bearings wear out as you just stated.
    If trying to save time/effort/money just get a replacement diff to toss in.
    If you have been driving it noisy for quite some time its likely the ring and pinion has been worn funny also.
    If super lazy/cheap Toss diff in trash....replace w used diff
    Sent from my GT-N7100 using Tapatalk 2
      If any of the bearings in the differential need to be replaced the backlash, pinion engagement depth, and pinion pre-load have to be set. It makes no sense to to do the job half way on a differential of this age and probable mileage.
      • redlightpete
        • Mar 2012
        • 266
        Thanks for the direction. Just trying to potentially save some work and buying shims if the carrier bearings last 10x as long as the pinion bearings. I guess if the pinion bearings are worn enough to be loud, the carrier bearings have been operating in their mess and are no longer on the semi-infinite life plan.
        • Wanganstyle
          • 2828
          320k and the unit has hit its wear items expected lifespan....100k ago
