Filling trans through vent hole?
  • eurolife
    • Jan 2013
    • 128
    Hey guys, having issues getting the full plug off on my trans. I know I can get a tube up there to fill the trans, but is there a reason I shouldn't fill from there other than not knowing how much fluid is in there?
  • chance
    • Feb 2012
    • 671
    It will come off, mine was tight as shit.
    The vent hole on my g265 is tiny, so it would take forever to fill, but should be doable.
    1991 335is in progress
    • redsubdivisions
      • Feb 2011
      • 1762
      Grab a pair of vice grips, get a steel grade bolt that fits (17mm, I believe) and put them on pretty tight. It's a pain, but at least you will be able to fill it to the correct amount.
      1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
      2012 Passat TDI - DD Duty
      2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
        • 34837
        make a tool using a couple nuts and a 17mm bolt.
        • JinormusJ
          • 6887
          Why not just fill it through the reverse light hole?
          Its much more accessable than the fill hole whoch is right directly interlodged between the trans and firewall. if you want to do the vent hole though, a G260 will take 1.3; I'd fill it up with at least that to be sure, maybe 1.5 for safe measure if you are able to get the drain plug off
          I've had the issue where my drain plug wouldn't come off an I had to siphon the oil through the full plug. Luckily, the G260 I have now has the nut headed-bolts (much easier to deal with), not the easily stripped female-torx head
          #e30problems
          • Todd Black 88
            • Oct 2007
            • 3449
            It's fine. A friend ran a line from the vent, to under his hood, on his Pro3 race car. He removes the fill plug on the tranny, and fills from under the hood untill it spills out.
            Done.
            Originally posted by codyep3
            I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
            2001 silver/Blk 325 cabby. SOLD
            2002 325xit Sil/blk. SOLD
            2010 F650gs twin
            • eurolife
              • Jan 2013
              • 128
              Wow, thanks for all help guys. I realized I didn't mention where I wanted to fill from (the vent hole)... You guys still helped out.
              I'll give a few of these tips a try and let you guys know.
              • TurboJake
                • 3780
                Made it a snap.
                Getting the plug off can be tricky though. I bought a hex key, and cut it down to make it stubby. Works a treat.
                Leave Me Transaction Feedback
                • eurolife
                  • Jan 2013
                  • 128
                  I got it off thanks guys! I had to use a torch to heat up the loctite on the plug.
                  • Thizzelle
                    • 4422
                    I had to buy a hex, cut a piece off then have one of my machinist grind it flat. Then I was able to put a wrench on it because it was way over torqued. And fits much better with firewall so close.
                    "I wanna see da boat movie"
                    "I got a tree on my house"
