I asked my machinist about doing this and he was more than willing but required the crank so that he could balance them together. From what I've been reading this is not necessary............... Any ideas?
The crank should already be balanced, so as long as he balances the flywheel, it should work.
I'm wondering if anyone has an idea of what the step is for on the clutch side of the fw. I measured it this morning and it's only .010" which seems basically negligible compared to the overall thickness of the flywheel. Does this .010" really make a difference and why?
Also, should I remove the 3 dowel pins from the fw before taking it to the machinist, or will they do this?
What should I specify to have the flywheel reduced to 12-13lb? The flywheel thickness is already at 32mm (and it weighs 20lb now), so I don't see a way of removing any material from the clutch side, and the machinist I'm working with estimated that you could only remove about 3-4 lb from the crank side.
Any advice is greatly appreciated, as this car is my DD and my only vehicle, so I would like to get it on the road again asap. Thanks!
