The average shaved M20 flywheel goes from 19-20 lbs to down to 13-15 lbs. The difference of 5-6lbs is VERY noticable, as it would be in the 5-6lbs additional difference from a shaved M20 flywheel to an aluminum one.
shaving a flywheel
Is it somewhat comparable to adding hp?Moving sale: Everything Must Go!
FS: 2001 740iL Sport, low mileage..... SOLD
FS: 1990 Mtec II 325iS, $12,0K OVNO
FS: 2003 Honda Odyssey EX-L Navi..... SOLD
FS: New Rieger lip, lachsilber metallic (WILL INCLUDE W/e30!!)
FS: Very rare, new lachsilber metallic E30 Aero pack sideskirts... (WILL INCLUDE W/e30!!)
Extreme 325iS (well, slowly getting there, anyway)......
Almost too many mods to list ;-)
Ya My flywheel comes in at 12 lbs exaclty and was balanced and resurfaced at the shop i took it to. I could have gone lower but he said he wanted to keep it streetable at 12. My car runs great and i never have to use the brakes around town. They sent me a dual mass flywheel when i ordered it and i ended up getting it lightened, balanced, and resurfaced for less than it cost to buy a brand new flywheel.
-Ali
12 is the sweet spot for steel flywheels.
and the disc side
lets also talk about minimum thickness
4cyl. engines
84-85 = 23.5mm (.925 in)
6 cyl. engines
1984 = 25.0 mm (.984 inches)
1985-1990 = 32.0mm (1.26o inches)
open the Bentley to section 4 and page 58 to see the "a-step" cut (flange height)
weight can be ultra light, but remember to consider the warping.
steel is more durable than alloy, but my rule of thumb (or writs) is
never machine a flywheel thinner than the pressure plate (which would be hard to do)
when they machine it, also request all edges be rounded out.
also ask about the flange height (if they know, bmw doesn't specify what would reduce pedal throw to the point of not ever releasing the disc, and to perfectly release it at its minimal throw)
this is where experience comes into play.
ask you local track.
luckily, when i brought mine in, i already asked around, called around,and when i deliverd the f.w. i found 5 different posters of e30s...
thats a score.
to add.
if you can afford it, have your p.plate balanced to your flywheel when its all done.
they will have to mark both f.w.and p.plate so you can re-align them when you install it. but its worth it.
have fun.3 pedal club
200,k+ club
cabrio club
port-matched- polished- purring www.BMWpark.org
</div>
linux since 1999
iwoops, didn't realize this thread was ressurected from almost 20000years ago.3 pedal club
200,k+ club
cabrio club
</div>
linux since 1999
Haha, it seems so.
I got mine taken down to about 12 pounds, it's great now. Revvs so quickly :-DMoving sale: Everything Must Go!
Yes, it does make the idle a little less predictable. In fact, with my Jim C chip and Schrick 284/272 cam, the idle is quite rough, and if I run with the AC on, the car can stall when I depress the clutch (the revs drop too quickly). But I'm sure that with a stock cam, this would not be a problem.Moving sale: Everything Must Go!
