Early vs late differential - vehicle speed sensor
  • Cyrix2k
    • 593
    I swapped a 1985 2.79 LSD into my 1991 318i. While it bolts up fine, the plug for the vehicle speed sensor is different. Can I resolve this by swapping in a '91 speed sensor or there more to it? It kind of sucks not having a speedometer.
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
  • reelizmpro
    • 9559
    Changing the sensor should solve your problem.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • Bmr
      • Jul 2009
      • 322
      Does it hit the back in the diff?
      • Cyrix2k
        • 593
        I swapped the sensors and the speedometer works. I think it's off by a wide margin though - I swear it reads 55 mph at 2000 rpm and 80 mph at 2500 rpm. The calculated speeds based on gear / wheel size should be 49.6 mph at 2000 rpm and 62 mph at 2500 rpm. Any ideas on that one? I'll have to check this with GPS.
        1997 540i/6 - stock
        • Holland
          • Nov 2008
          • 7212
          This. Had to do the same thing when putting a late diff in my 85.
          Originally posted by DEV0 E30
          • AndrewBird
            The Mad Scientist
            • 11898
            Using the factory tire size (195/65-14) and the gear ratios found here for the Getrag 240, you should be taching 1720 RPM at 55 and 2502 RPM at 80.
            Here is the calculator I made and use. Click the download link at the top to download the file and open in Excel.
            • Cyrix2k
              • 593
              https://docs.google.com/file/d/0B4aq...it?usp=sharing
              Thanks, I'm an idiot. I thought 5th was 1:1 on the 240... my speedometer is reading correctly and I recalled the rpms incorrectly in the post above.
              1997 540i/6 - stock
