Airbag pedal box vs non airbag box. Help!
  • dunebuggyjay
    • Nov 2011
    • 257
    Hi Guys,
    I have an 88 vert with an automatic, that I want to swap a 5 spd into.
    I also have a 91 e30 parts car that just so happens to be a manual.
    The 88 has an early pedal assembly. The 91 obviosly has the late model airbag pedal assembly.
    I tried to take the pedal assembly out of the 91, and noticed its way differnt than the 88's.
    So do I absolutly need an early pedal box for the 88, or can I just use the late model box (once I figure out how to remove it)
    Or can I just swap the pedals from the airbag car into a non airbag pedal box?
    Thanks!
    Jay
    I'm not positive, but I think you can swap just the clutch pedal.
    • AwakenNoMore
      • Dec 2010
      • 1291
      I was told they are interchangeable. Hope it's true because I have pedals out of a non airbag car and mine is (or rather was) a airbag equipped.
      1991 325i - "Scambles" The Daily Driven lightly modded.
      1988 Mazda RX-7 TII "Mako" The Free Dorito
      bacon by Jared Laabs, on Flickr
      • whodwho
        • Jun 2008
        • 1547
        Just swap the pedals in and don't worry about the clutch pedal spring assembly if it is different and won't work.
        My M20 Frankenbuild(s)
        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
          • 37833
          The auto non airbag pedal box won't have the holes to mount the clutch master cylinder.
          Just find a complete non airbag stick pedal assembly and swap it in.
          Grover Beach, California
          BimmerHeads.com
            That may be true in some cases, but I did not encounter that problem on an 87 325is.
