HELP! Clutch wont engage after 5spd swap!!!
  • Overlord475
    • Dec 2010
    • 799
    Just got done buttoning everything up after a 5spd swap in my 88 SETA.
    Used a Dual Mass Flywheel and this clutch kit:
    http://www.ebay.com/itm/151062688299...84.m1497.l2649
    Started the car and clutch won' fully engage.
    The car will barely move when in gear and the clutch is smoking a little.
    It's like the clutch is slightly disengaged just enough to not make good contact.
    What would cause this to happen?!?!
    Could I have installed the clutch disc backwards our maybe used the wrong throw out bearing?
    Please help
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • serdar255
    • Feb 2013
    • 395
    Maybe try to re bleed the clutch.
    image (10) by serdar.gurhan, on Flickr
    PM me for custom shift knobs and stickers!
    Originally posted by marshallnoise
    You ain't done working on a car unless you are bleeding.
    • DesertBMW
      • Aug 2011
      • 1042
      Please help
      dual mass flywheel comes in different depths, so you must use the matching flywheel.
      Whats the part number of the flywheel?
      • Overlord475
        • Dec 2010
        • 799
        Not sure of the PN
        Pulled it off of an 85 325e
