Cant separate trans from block
  • serdar255
    • Feb 2013
    • 395
    Im about 50% done with my 5 speed swap but cant separate my transmission from the block. Any tips? I have no idea what im doing wrong.
    image (10) by serdar.gurhan, on Flickr
    PM me for custom shift knobs and stickers!
    Originally posted by marshallnoise
    You ain't done working on a car unless you are bleeding.
  • TobyB
    • 5243
    Check again for bolts you've missed?
    t
    • serdar255
      • Feb 2013
      • 395
      t
      I checked like 5 times.
      • kronus
        • Apr 2008
        • 13032
        If you haven't unbolted the torque converter from the flywheel, you need to do that. Take off the rear oil pan cover thingy that covers up the bottom of the bellhousing, rotate engine until you see a bolt going into the torque converter, unbolt, repeat 2x.
        cars beep boop
        • serdar255
          • Feb 2013
          • 395
          So this is my only problem?
          I didnt see that in the swap instructions.
          • kronus
            • Apr 2008
            • 13032
            I don't know if it's your only problem, but if you haven't done it, you should. The shaft it sits on in the transmission won't let it go unless it's perfectly straight, which rarely happens. Unbolting is far easier.
            cars beep boop
            • serdar255
              • Feb 2013
              • 395
              Ahh i see, thanks for the useful information!
