Clutch engage point is very high (at the end of the pedal trevel) Disk is fine...
  • Batz
    • Aug 2013
    • 303
    Hello all. So what i mean by this, is that when i start the car in order for the clutch to "engage" i need to let the clutch pedal off almost till the very end. And only in the end it starts to engage. I thought it was the disk at first, so i took the tranny out, but the disk is fine. What can it be? Can it be the clutch release bearing?
    Also in some cars you can adjust it, is there anyways you can adjust the clutch in e30?
    Thanks
  • Dj Buttchug
    • Jun 2010
    • 7688
    is it all stock?
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • whodwho
      • Jun 2008
      • 1547
      Have you checked the pin that the fork pivots off of?
      Part #5 if this shows up
      My M20 Frankenbuild(s)
      4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
      • Batz
        • Aug 2013
        • 303
        Yes all stock, and no havent checked the pin. What should i look for when i check it? Thanks for replies.
        • whodwho
          • Jun 2008
          • 1547
          They are made of plastic and wear down, they should be replaced whenever apart.
          • Batz
            • Aug 2013
            • 303
            So i checked the pin, and it seems perfectly fine.
            • Batz
              • Aug 2013
              • 303
              Any other theories of what it might be?
              Sent from my HTC VLE_U using Tapatalk 4
              • KVF
                • 297
                Don't the springs in the clutch/pressure plate contribute to that as well? If you have it all apart, I'd put in a fresh clutch kit and replace number 5 & 6 from the diagram above.
                • Batz
                  • Aug 2013
                  • 303
                  Yeah, already ordered the kit, should come on Wednesday, hopefully it will fix it. Thanks all
                  • Slovik
                    • Jan 2010
                    • 198
                    You don't say what transmission clutch combination you are using, but use a metal washer or two between the slave cylinder and the transmission bellhousing. You probably just have a slightly taller clutch release bearing in there.
                    • Batz
                      • Aug 2013
                      • 303
                      Actually will have to try that. Because the new clutch kit came, and there is barely any difference. Maybe like .5mm difference on a disk, probably even less then that.
                      Thanks
                      • KVF
                        • 297
                        It's not your disks that are going, it's likely the pressure plate. That's why it doesn't slip at all, but releases so early/easy.
                        • whodwho
                          • Jun 2008
                          • 1547
                          Comparing it to what? they start out with a bit of a point and tends to wear down round and gets shorter so hopefully you are putting a new one in. it should always be replaced whenever the trans is out, it is a $1.25 part and you wouldn't want to have to pull the trans again just to replace it. 8^)
                          Or you can upgrade it to a nice bronze one -
                          http://www.pelicanparts.com/cgi-bin/...FILTER_BMWM=ON
                          • Batz
                            • Aug 2013
                            • 303
                            Yep, im putting the new one anyways. Thanks for the link btw.
                            And the pressure plate is fine as well.. Compared it to the one that came with the new kit, and its basically exactly the same, except dirty...
                            • KVF
                              • 297
                              It's not just the physical appearance. You'd need to measure the resistance of the springs on the clutch and pressure plate to tell if they were bad.
