flex disc/drive shaft bearing question.
  • Calypso Moor
    • Sep 2013
    • 91
    I need to replace them, I have the parts, but no money, and a mechanic told me I needed a press to do it, is that true? or can I just do this in the Garage at home?
  • bmwman91
    • Oct 2004
    • 3134
    You can replace the flex disk / "guibo" yourself relatively easily. By "driveshaft bearing? if you mean the center support bearing/bushing, then yeah that's easy. If you mean the universal joints...you should just start looking for a replacement driveshaft.
    Transaction Feedback: LINK
    • Calypso Moor
      • Sep 2013
      • 91
      so I don't need some kind of dress then? good, glad I don't go to that mechanic except for tires.
      • agent
        Vice Grand Pubaa
        • 7960
        Not unless that's going to be your form of payment.
        Originally posted by kronus
        • nyChris
          • Apr 2012
          • 395
          Your mechanic may be referring to the centering sleeve. Number 1 in the diagram below.
          The Bentley says to pack it with grease and use rod stock to press it out. However, if the bushing is damaged this will not work. I used a slide hammer, and it came out very easily.
          • bmwman91
            • Oct 2004
            • 3134
            Good call. I have never replaced that bushing actually. A little silicone grease has always been needed to make it slide onto the output shaft properly though.
            One more note: The center support bearing can be a pain in the ass to get off of the driveshaft. You do NOT need a press, but it can take a good amount of fiddling with a big screwdriver, or in extreme cases some very careful work with a Dremel to slit the sleeve that fits tightly on there.
            • Calypso Moor
              • Sep 2013
              • 91
              where in the bay are bmwman?
              • Calypso Moor
                • Sep 2013
                • 91
                Gods damnit.
