So after being off the road for about 10 years my e30 had to make a jump to dd status. Anyways in low speed corners like in a parking lot some thing is chattering and making noise in the back. I am thinking maybe the diff fluid friction modifier is toast. Anything else you guys would check out. I will do the fluid change right away for good measure. I did open the fill plug and the fluid looked ok and it leaked out some. So its not empty.
Chatter when slow speen turns?Lsd fluid?
1987 325is- $700 project car
1996 Pontiac Firebird Formula - Bolt ons,cam, 6 speed of fun.
2001 Miata - Current DD and to be for sale soon.
The Build- http://www.r3vlimited.com/board/showthread.php?t=281011
Parts Car Part Out Left Overs- http://www.r3vlimited.com/board/show...21#post3860521Tags: None -
sounds like subframe bushings are worn or the rear CV's need to be re-packed with fresh grease.
you don't need friction modifier in these units for them to be quiet; it might chatter when brand new 0 miles but not if its an original unit.OBD1 M54/M52TU swap as a M50b25
