Just swapped my I transmission into my eta
  • MAC-GOOB
    • Nov 2013
    • 2
    AND I got a question, cause obviously all the 260s are not the same. THose two sensors that get plugged into the bottom of the drivers side of the transmission, well this I transmission doesnt have it. DO I need them.
  • frankenbeemer
    • Sep 2009
    • 2260
    Will the eta start?
    Don't buy an e30
    They're stupid
    1989 325is Raged on then sold.
    1988 325 SETA 2DR Beaten to death, then parted.
    1988 325 SETA 4DR Parted.
    1990 325i Cabrio Daily'd, then stored 2 yrs ago.
    • McGyver
      • 4636
      yes you need them. this should have some of the info:
      from what i understand, the 325i has a crank position sensor in a different spot. the eta sensor is on the flywheel.
      • Swanny
        • Mar 2012
        • 2834
        Yeah those connectors are your engine speed sensor and CPS. If you convert to montronic 1.3 you'll be in the clear. Might as well grab an I head and slap it on while you're at it.
        Swanny!
        SUCKERS.
