Drive Shaft for Getrag 420g
  • GAbOS
    • Mar 2012
    • 523
    Hey all..
    Currently swapping in an M60 and have a question regarding what drive shaft to use with the Getrag 420g 6-Speed. I've been looking all over and it seems that it's the same part for both the 5-speed and 6, but people are telling me this is not the case. I'm getting conflicting information and really need to clear this up as this is the last bit of my project and I'm ready to drive!
    I know I need the front half from an e34, but do I need to make sure it is 6-speed specific?
    Any help would be appreciated.
  • nrubenstein
    • 3148
    Easiest solution is just an E36 M3 automatic driveshaft.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • GAbOS
      • Mar 2012
      • 523
      I just checked out realoem and they show the e36 M3 Auto and Manual to have a 96mm flex disc where the e34 6-speed's is 105mm. I'm still just as lost. ;)
      Anyone else have any more info for me?
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        I thought you needed an eta or M3 shaft(big guibo?), and then had to get it shortened to fit?
        Originally posted by priapism
        Originally posted by shameson
        • GAbOS
          • Mar 2012
          • 523
          From what I can tell on real oem, the eta/m3 is also 96mm.
          Sent from my SAMSUNG-SGH-I727 using Tapatalk 4
          • GAbOS
            • Mar 2012
            • 523
            Found a neato cross reference link on RevShift's site.
            http://www.realoem.com/bmw/partxref.do?part=26111229065
            • Wanganstyle
              • 2828
              buy the triangle output flange from a E46 M3; they run a G420 unit.
              SMG or 6mt manual it doesnt matter.
              its 96mm. Then run e36m3 auto driveshaft (complete)
              only dirty PNP resident R3vtards willbe mix matching drivehsaft parts- and they are too poor/cheap/dirty to spend the $30 for balancing.
