What additive will stop the leaking LSD?
  • goinstrong
    • Jul 2008
    • 215
    Help!
    Anyone know if there is an additive I can put into the LSD of a 1988 325iC? It is not the drain plug that is leaking...I verified that. I don't want to mess up the limited slip gearing. Thanks in advance for your help.
    Tim
  • FLG
    • Sep 2011
    • 3165
    Nothing.
    Either leaking from the cover or the speed sensor or half shafts.
    Clean it and locate where it's coming from. Speed sensor is a simple o ring, cover is easy to, half shafts are just seals they're simple just a bit more work.
    Sent from my SCH-I545 using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • gtdragon980
      • Jun 2008
      • 1808
      I doubt there is really any additive that can actually stop a leak that has already occurred. if it is leaking bad, I suggest getting it resealed. If it is an extremely slow leak, you could try some stuff from your local hardware store. In my experience, it's total junk unless your leak is very small.
      FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
      Originally posted by scabzzzz
      I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
      1989 325i - Project/weekend driver
      2002 325i - DD
      2005 Suzuki SV650 - Toy
      • goinstrong
        • Jul 2008
        • 215
        Just something to swell the rubber a little bit is what I was thinking. If they swell too much, then I would take it all apart and reseal it. I am just trying to put it off since I just started a new job and time is very tight.
        Tim
        • FLG
          • Sep 2011
          • 3165
          Tim
          Depends on what's leaking and how it's leaking.
          Take a moment and find out, could be as simple as the speed sensor... And that's a 5 min and 50cent job.
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            I would add new seals and gaskets. But that's just me.
            • Hick
              • Sep 2005
              • 6451
              Afternoons work and not a huge cost. If you really want to save the LS unit, do it right.
              Originally posted by vlad
              • FLG
                • Sep 2011
                • 3165
                QFT
                • Hooffenstein HD
                  • Nov 2012
                  • 1388
                  This. They are cheap.
                  • Poorboyz
                    • May 2012
                    • 2117
                    New seals and gasket doesn't cost much...AT ALL. Just replace it.
                    I wouldn't put anything in my diff, engine, trans that would make gaskets swell up...That's just being lazy and not fixing the problem.
                    I have brand new spare seals and fluid if you're needing them.
                    Sent from my Galaxy Nexus using Tapatalk
                    Rebuilding since 07/06/2016
                    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                    Poorboyz Feedback Thread
                    • QUKBMER
                      • 8178
                      Ahhhhhh yeah this buddy ^^^ lol . There is no sealer to stop your diff from leaking brah.
                      • Jand3rson
                        • 37587
                        Elbow grease. Be sure you check the tolerances on the output shafts before you bolt it back up under the car.
                        • TobyB
                          • 5263
                          If it's not leaking from the pinion seal, (driveshaft flange) it's easy.
                          t
                          • Wanganstyle
                            • 2828
                            the adding of of:
                            Labor (~ 3-5 hours)
                            new parts (seals x3, O rings x3, surface gasket x1)
                            not leaking rear end.
                            For a non-worn and non-ancient rear end its quite a lot more hours and parts.
