325e (Dual mass 87') Clutch replacement
  • Ark
    • Jul 2013
    • 16
    Pretty soon, I'll be putting a new clutch in my 87 e. My question is, but i'm not quite how to go about switching to a single mass flywheel. Am i stuck tracking down an early flywheel with tabs for the 2 Crank position sensors? Any Help from someone more experienced than myself is appreciated! :)
    Yep, if you want a single mass flywheel you will need the early one with the timing slugs.
    • LateFan
      • May 2013
      • 4438
      What are the advantages of one over the other? Which does an '86 e have?
        An 86 would have a dual-mass flywheel. The solid flywheel can be resurfaced and is simpler.
