so im replacing my guibo and CSB and am stuck on taking off the guibo. so far i removed the three nuts of the driveshaft dampener to the guibo. all thats left are the nuts and bolts that connect the guibo and the tranny output flnge. THEY WILL NOT COME OFF. im using a 17mm open wrench and its just slipping, no the nuts arent 16mm. im using a very strong penetrant and still no luck. at this point my body is killing me and mentally had enough. why wont they budget a single bit? any suggestions? im really stumped
flex disc/guibo help!
Tags: None
so im replacing my guibo and CSB and am stuck on taking off the guibo. so far i removed the three nuts of the driveshaft dampener to the guibo. all thats left are the nuts and bolts that connect the guibo and the tranny output flnge. THEY WILL NOT COME OFF. im using a 17mm open wrench and its just slipping, no the nuts arent 16mm. im using a very strong penetrant and still no luck. at this point my body is killing me and mentally had enough. why wont they budget a single bit? any suggestions? im really stumped -
hopefully after leaving it thoughout the night, the penetration oil will do its jobComment
Both the bolt and nut heads are 17mm, right? I usually get a box wrench on the nut head (tranny side) and a breaker bar on the bolt head. Position the box wrench so that it jams against the chassis or tranny and pull steadily with the breaker bar. You'll need to jack up the rear end and rotate the wheels to get the nuts/bolts in the ideal position for this.Comment
