Vibration in rear at certain speeds
  • jesse_e30
    • Dec 2013
    • 37
    Ok, so I get this vibration that feels like its coming from the rear. I only feel it at 65mph and above 85mph. Now I know it cant be me driveshaft or CSB or guibo cause those are all brand new. And I thought it might have been my rear tires caus they were worn down to the steel belting, so I replaced those, and it helped out a lot, which means the vibration isn't as bad as it was but its still there. Any ideas? and only at those speeds any other speed is smooth
    sigpicWhat is that?... a lufa?... Its a Quinoa!
    1989 325i, 1970 Chevy El Camino
  • Bglad
    • Jul 2010
    • 562
    Tire balance. I had the same issue. You may need a road force balance.
      A vibration that comes and goes at various speeds will be out of round or out of balance tires. Worn shocks or suspension will aggravate minor tire problems.
      • mathillois
        • Sep 2012
        • 71
        i have a slight vibration going 25-28mpg from the mid rear and i did the cbs and guibo. any ideas?
        • jesse_e30
          • Dec 2013
          • 37
          I just had all tires re-balanced when I replaced the rear tires
          • jesse_e30
            • Dec 2013
            • 37
            My Billy sports only have about 2k miles on them
            • jesse_e30
              • Dec 2013
              • 37
              maybe worn bushings? I know these need replacing soon
              • Sea Aych
                • Apr 2013
                • 765
                I have a very similar issue to you, going an (indicated) 60-80kph. Do you get a droning noise too?
                Check your half axle shafts for play. My rear left one has very slight play and i think it's causing my problem.
                Check your u-joints on your driveshaft.
                Bad alignment can cause slight vibrations too (although that's pretty obvious to notice if you need an alignment...)
                Jesse_e30, you could probably check those too!
                1988 Atlantisblau Euro/Japanese 325i Cabriolet
                1989 Schwartz 325i - now M50 powered! - now very dead
                1998 Toyota 4Runner Limited
                My 17,000km Big NA National Parks trip!
