Who has solid mounts
    put the clutch in while rolling at 50mph and you'll notice it stops vibrating. Its just how the UMHW mounts are
    7speedshop.com
      ya that just proves the same thing as revving the motor while stopped. The vibration is the motor, not the driveline.
      If m20's just arent that balanced and they wobble a little like this through the revs its fine by me, I just want to make sure its normal before taking off on a long road trip and sheering off my transmission tabs and motor mounts haha
        haha, yeah its normal, it seems to smooth out a bit after 100miles
        7speedshop.com
          I got solid aluminum motor and transmission mounts from akg, installed both and ended up going back to oem transmision mounts because the vibration transferred into the cab was WAY TOO MUCH
