Tranny swap
  • Dallin97
    • Mar 2014
    • 59
    Tranny swap
    I'm not gonna start a whole new thread cause there are plenty of how to's on multiple forums. My main question is the swap procedure the same on a sedan as it is on a coupe cause I have a 1990 325i sedan
    1990 325i sedan Turbo project.
    • 37833
    I hate to break it to you but this is a thread and you've started it. ;)
    There is no difference in sedan vs. coupe. Your car is an airbag car though so instead of swapping the complete pedal assembly you can just swap the pedals themselves.
    Grover Beach, California
    BimmerHeads.com
    • Dallin97
      • Mar 2014
      • 59
      I meant I wasn't gonna start a hot to thread because is already so many and I would assume that the drive shaft would be a different length in the sedan than the coupe and every where I've looked didn't ask wether or not it was a coupe
      • Dallin97
        • Mar 2014
        • 59
        ^^^^How to
        • Poorboyz
          • May 2012
          • 2117
          Doesn't matter if the parts came from a coupe or sedan. The only thing that matters is the pedals as Mr 325 said.
          Sent from my Galaxy Nexus using Tapatalk
          Rebuilding since 07/06/2016
          Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
          Poorboyz Feedback Thread
          • noahb
            • Dec 2012
            • 125
            Learned that one the hard way
              • 37833
              Cars are the same size.
              BimmerHeads.com
              • Dallin97
                • Mar 2014
                • 59
                K that was my only question so it's just a manual drive shaft and it doesn't matter If it's coupe ore sedan I found a place that sells rebuilt trannies for 550 http://www.catuned.com/p/59/catuned-...0#.UyDuotyDTeI
                • frankie591
                  • Feb 2012
                  • 545
                  Just find somebody parting a 5 speed car and buy the complete swap. Not worth that money for a rebuilt trans, getrag 260's are bulletproof so even a used one will keep going forever.
                  • Poorboyz
                    • May 2012
                    • 2117
                    I agree with buying a complete swap. Maybe even buy a complete 5spd car, that way you'll have all the parts including braces, exhaust, etc..
                    I will have to disagree with the G260s being bullet proof though.
                    GL OP
                    • PimpinWalrus
                      • Oct 2013
                      • 170
                      Go to Chesterfield Auto, you can get one for $100.
                      '86 Delphin 335i turbo -
                      '88 Schwarz 325i -
                      '94 w124 e420 -
                      Turbo m30b35 Build Thread
                      • Dallin97
                        • Mar 2014
                        • 59
                        will do i hope to the swap in the next couple weeks when i get my dads e39 m5 put back together, we are doing a rear main seal and a shot throw kit on it,
                        is Chesterfield auto like a wrecking yard or a pic and pull
                        • PimpinWalrus
                          • Oct 2013
                          • 170
                          It's a pick and pull, and everything is dirt cheap. I think their is a manual diamond schwarz 4 door at the Richmond site. Seemed like it just needed shifter rebuild. I did a 5 speed swap about 3 months ago so if you have any questions (Which i know i did, wish someone told me not to spend 3 hours pulling out the airbag pedal box) PM me and i can try to help! I'm also local if you need some hands on.
                          Good luck!
                          '88 Schwarz 325i -
                          '94 w124 e420 -
