So this is the third or fourth time I've removed/installed one of my various differentials. This time around, I don't know what I'm doing wrong, but I'm having a very hard time getting the four top bolts lined up. Please share your tricks. BTW this one has been in before.
Differential re-install, PITA
I typically start one loosely and use a locating tool to center the others. Sometimes they go right in , others give you a bit of trouble. Good luck -
you and your issues with tools going in...
Seriously, though, they just do that sometimes - even when we have them on the trans jack and the car on a lift. Start them very loose and this will give some wiggle room to get the other started. Don't tighten any until they are all in by 3-4 threads. also helps if the mount bolt is NOT in as this will cause the diff to rotate at weird angles.Comment
