How far does the manual transmission drain plug screw back in? I put it back into my 91 318is but 3 or 4 of the threads are still exposed but it's turned in quite a bit already and is really tight and won't budge (torque wrench is clicking at 30ft lbs.. I didnt' want to go to 40 which is the recommended rating or strip something)
Anyway, is this normal? No leaks or anything, and I can't remember how it was before.
Used Valvoline Max Life ATF instead of Redline, because bavauto recommended and sold me the wrong fluid (MTL). grr.
