Hi all,
I am working on a 5 speed swap in a 91 airbag e30. Currently the pedal assembly has bolted on and swapped without concern. The pedals have come from a non-airbag car.
Everything seems to have lined up/boted up so far.
The only concern i have is the rear brake light switch is not engaged by the brake pedal when it is a rest. Has anyone else had this issue? Do the Airbag 5spd cars use a different brake pedel? Or do they use a different switch?
Any help would be much appreciated!
thanks!
thanks!
