vibrating after 5speed swap
  • trujillo937
    • Aug 2013
    • 16
    Alrighty guys so here's the deal. I did a 5speed swap on my 88 325 and used the parts from my wrecked 89 i have laying around for parts. I also installed a 373 lsd and solid condor speed shop mounts all thru the car.so at any speeds after 40 the rear and starts to virbate pretty bad. Would i need to balance my driveshaft or maybe refurbish the lsd??? Any input please??d
  • oliver.r
    • Mar 2012
    • 3839
    my guess is your driveshaft, if you dis-asembled it and put it back together off balance that could be whats causing you rproblem
    • Sea Aych
      • Apr 2013
      • 765
      How far back? Do you feel the vibration in your seat as well?
      Put your hand on the transmission tunnel and see if you can find where it's the strongest.
      My guess would be, if you're using only parts from the wrecked car - it's your CSB or you just need the driveshaft balanced - see if you've got any significant play in the u-joints as well - that could cause vibrations at higher speeds as well
      1988 Atlantisblau Euro/Japanese 325i Cabriolet
      1989 Schwartz 325i - now M50 powered! - now very dead
      1998 Toyota 4Runner Limited
      My 17,000km Big NA National Parks trip!
      • AwakenNoMore
        • Dec 2010
        • 1291
        you installed condor solid mounts everywhere, did not expect more vibration?
        1991 325i - "Scambles" The Daily Driven lightly modded.
        1988 Mazda RX-7 TII "Mako" The Free Dorito
        bacon by Jared Laabs, on Flickr
