really weird shifter problem, help? :(
  • zerotolerancecuy
    • Jan 2014
    • 33
    hey guys. ive had this really weird problem with my shifter since i got my 88 325i 4 door. the shifter sits about 2 inches forward, so much that the PO cut out part of the center console so he could still shift. the guy told me that it was just the shifter linkage and that he put the wrong kind in, but i would like everyones ideas on what it might be before i go and buy it.
    Keep it sideways!!! XD
  • Poorboyz
    • May 2012
    • 2117
    I believe its exactly what you claim the PO said it is.
    What is happening is the linkage is too long therefore pushing the shift lever inside the car forward. Just get a OEM E30 one and you should be fine. Its a 10 minute job and most of that is lifting the car.
    GL
    Sent from my Galaxy Nexus using Tapatalk
    Rebuilding since 07/06/2016
    Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
    Poorboyz Feedback Thread
    • zerotolerancecuy
      • Jan 2014
      • 33
      well that would be nice if it is just that.
      • zerotolerancecuy
        • Jan 2014
        • 33
        anybody else ever had this problem?
        • zerotolerancecuy
          • Jan 2014
          • 33
          ok, just found a diagram of the shifter assembly here (http://bmwfans.info/parts-catalog/E3...ting_part_2#13) which parts do you think needs replaced? :/
          • Poorboyz
            • May 2012
            • 2117
            #10, you need a shorter one
            • Simple_Smith
              • Aug 2011
              • 584
              Either that or the PO installed the shifter backwards
              1989 JDM-Tech 2
              2010 335 D for daily
              • zerotolerancecuy
                • Jan 2014
                • 33
                ok, cool, thanks guys
                • zerotolerancecuy
                  • Jan 2014
                  • 33
                  im pretty sure this will be a shit ton of work :/ i have to remove the exhaust and heat shielding right?
                  • Poorboyz
                    • May 2012
                    • 2117
                    No, you just loosen the e rxhaust to remove heat shield. You might even be able to do it without removing heat shield. If you think this is a ton of work than you're probably not very mechanically inclined.
                    Sent from my HTC One M8 using Tapatalk
                    • HennaE30
                      • Apr 2014
                      • 1965
                      That'll only take you 5 minutes and replacing the shifter takes about 10. I think it's exactly what PO says it is. And if you think this is a shit ton of work do yourself a favor and never do a motorswap lol
                      Originally posted by flyboyx
                      how about if i yank the anal beads out of your ass like i'm trying to pull start a chain saw?
                      Originally posted by Northern
                      beer is my new liver cleanse.
                      Henna - '84 Hennarot 325e
                      Lola - '89 Schwarz 325is - being saved
                      Christine - '88 Schwarz 325is - Spec E30 Racecar
                      '01 White F150 Lariat 4x4 Supercrew - Daily
                      Dad's '05 Interlagosblau M3
                      • zerotolerancecuy
                        • Jan 2014
                        • 33
                        well i am very mechanically inclined @poorboys. i just haven't ever worked on an e30. my e36 you had to drop the exhaust and part of the driveline
                        • zerotolerancecuy
                          • Jan 2014
                          • 33
                          and no, its not a lot of work now that you guys have explained whats involved lol
                          • HennaE30
                            • Apr 2014
                            • 1965
                            E30s are really simple compared to the Ex6 cars... I do a bunch of work with my dad on his M3 and it's a bitch compared to the E30
                            • zerotolerancecuy
                              • Jan 2014
                              • 33
                              ok, cool. im glad lol :P
