I am doing an LS1 conversion on my e30. I'm using garret guide and they advice to use a Camaro driveshaft and change the diff flange for the BMW one. The camaro used both a steel and an aluminum one, which one should I use?
Should I consider modifying the BMW shaft, changing the yoke?
Thanks
Thanks
