driveshaft issues.
  • tylernaugle
    • Feb 2014
    • 36
    driveshaft issues.
    so doing a 5spd swap everything was going smoothly until I hit the 4 bolts on the driveshaft connecting it to the diff. 2 of them came out with hitting the 17mm wrench with a hammer. the other 2 seem to be stuck. ive been contemplating to angle grind them off but dont know if the angle grinder will fit between them to get to the bolts. any ideas? ive tried searching but it seems like theres hardly any issues with this.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk
    There is enough room to get a C type nut splitter in. Dunno if the type that fits over the nut will go in.
    • redlightpete
      • Mar 2012
      • 264
      If the bolt heads are still intact, figure out how to apply more torque. The worst case is that you twist them off, in which case the driveshaft can still be removed. I'd recommend heading to the hardware store and getting a couple pieces of pipe that fit over your wrenches.
      • tylernaugle
        • Feb 2014
        • 36
        I totally forgot about that tool. thanks for reminding me hoepfully it can crack that nut.
        • e30jake
          • Feb 2012
          • 855
          This
          Get more leverage, get on your back and kick it from the side of the car.
          What it feels like owning an e30:
          88 325 S50 swap in progress
          90 325ix
          • mpowerful
            • Jul 2013
            • 1273
            Heat it up with torch.
            • rhE-30
              • 498
              • tylernaugle
                • Feb 2014
                • 36
                thanks guys, I ended up angle grinding most of it and hitting it with a chisel. (heat didnt work either so I sakd screw it) Click image for larger version
ID:	7165387. Now how do I get this off? picture is trying to show both halves off and the driveshaft lock on it. do I use a puller for it? I was on pelican parts to no extent and searching the forums for a diy, but did not find one besides pulling the bearing off with a puller.
