Clutch Master or Slave Cylinder Problem
  • TexasTerp
    • Jan 2009
    • 3541
    on my e30, my clutch pedal has consistent pressure when I press the pedal down/in but it loses pressure once in and doesn't rebound.
    iirc, when my e36 slave died the pedal had no pressure at all. but that was a long while ago.
    Which do I need to replace: master or slave cylinder ?
    stephenbrody.com
  • TurboJake
    • 3780
    Well, it could be either. The symptoms for either going bad are exactly the same. So just replace both.
    Leave Me Transaction Feedback
    • TexasTerp
      • Jan 2009
      • 3541
      I'm about to take the slave cylinder off and test it. At least that's easier than taking out the master cylinder for the time being
      stephenbrody.com
      • blunttech
        • 12850
        just do them both The other is going to fail shortly after you introduce a new part to the system
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • ST1G
          • Oct 2012
          • 6690
          Yeah, it's really not that hard to change the master. Just takes a little bit of time. My pedal box broke the other day and had to pull it out and re-weld it. I bet you could replace the master in 1/4 the time.
            If there are no leaks at the slave or soft line, the master cylinder is bad. Given the probable age, replace the slave and the soft line along with the master.
            • TexasTerp
              • Jan 2009
              • 3541
              I just ordered new slave and master cylinders. Hopefully they should get here in a few days and I can get it back on the road.
              Thanks y'all!
              stephenbrody.com
