small output seal leak
  • Daeldalus
    • Nov 2012
    • 304
    I have noticed that i have a small output shaft seal leak
    small as in i noticed it a year ago and i have checked
    the fluid level regularly but it still is just a touch over full
    i have recently decided to drain it and refill with MTL but i dont
    want my leak to get worse and leak out my expensive fluid
    so could i add a little at205 rear main sealer when i change
    fluid to stop the leak or would this somehow damage my trans?
    or just not worry about it and change just change the fluid?
  • Liquidity
    • May 2014
    • 395
    Put a new seal in. Never use stop-leak products on anything ever except for a derby or 24hrs of Lemons car.
    • redlightpete
      • Mar 2012
      • 264
      Mine's been leaking for over a decade. I just make sure it is topped up every year or so. It's a little messy but it doesn't drip on the driveway or anything.
