i noticed my shifter was beginning to get really lose so i looked under the car. i took out that rubber that is bettween a plate that holds the shifter and a plate above the trans. relaced it with a bushing and a screw and has held up pretty good but still the shifter is pretty loose.
anyway i was driving and a bolt just fell off my car. so i went back for it and that night i checked where it came from. i think it holds the plate that is attached to the shifter...its a kinda big screw that needs an allen wrench to tighten it. every since then i can smell trans fluid and see after ive been parked for awhile see fluid leaking on the ground. i havent put the screw back but wen i checked it doesnt seem like any fluid is comming out from there.
anybody think they could help me or know where its leaking from. also anybody have the part number to that rubber between the two plates above the trans. thanks!
