88 SETA Flywheel
  • megu2ice
    • Jul 2013
    • 61
    88 SETA Flywheel
    I've just ordered a Spec Stage 3 clutch thinking I had a single mass flywheel but now I'm having doubts. From what I understand, the switch to single mass was around 86 but according to realoem, I have a dual mass. Can anyone confirm if the seta came with a single or dual?
    Build Thread
  • wilholl
    • May 2012
    • 518
    Mine was a dual mass
    1988 325 non-letter Seta "Bronzit"
    1991 325ic "Laguna Green" (Sold)
    1993 325i "Laguna Green/Silver" (Sold)
    1998 528i "Artic Silver" m-sport(totalled by drunk driver)
    2000 528i Titansilber/gray m-sport
    2000 528i Titansilber/black m-sport(sold)
    2001 525i Anthracite m-sport(sold)
    2013 750i Black/Black m-sport "Beast"
      • 37833
      Swap to a single mass M20B25 flywheel and you're good.
      Grover Beach, California
      BimmerHeads.com
      • megu2ice
        • Jul 2013
        • 61
        Yea I'm just on a bit of a time crunch. I guess ill start looking for the single mass now.
        Build Thread
        • csmitty
          • Mar 2013
          • 27
          Mine SETA is a dual mass and looking for a single currently. Its my understanding that the autos and manual 325i's have different flywheels? As cross referencing the PN on real oem pulls up autos as well as manuals. But when you go to the page it lists about 3 flywheels.
          Also am I correct in assuming SETA's don't need the reference pins on the flywheel since it uses the front CPS sensor.
          • SSR-125
            • Jan 2014
            • 578
            I have a single mass flywheel that i bought that i never ended up using. PM me if interested
            88' E30 325 24v Turbo Coupe
            91' E30 325i Sedan
            09' E82 135i Coupe (Sold)
            01' E46 325ci Coupe (Sold)
            97' E36 328is Coupe (Sold)
            91' E30 325i m52 Coupe (Sold)
            90' E30 325is Coupe (Sold)
            90' E30 325ic Coupe (Sold)
            88' E30 325is m20 Turbo Coupe (Sold)
            88' E30 325 Coupe (Sold)
            87' E30 325e Coupe (Sold)
            86' E30 325es Coupe (Sold)
            • megu2ice
              • Jul 2013
              • 61
              Just finished swapping my flywheel this weekend and no the seta does not need the reference pin. Not sure about the whole auto flywheel situation but I would stick to a manual if possible.
              Build Thread
                • 37833
                Super Eta does not use the trans mounted crank sensor. It's on the front of the engine.
                You can not use a auto "flywheel" in a stick shift car. A single mass M20B25 flywheel would be a direct swap for a Super Eta car. All M20B25 flywheels are the same single mass unit.
                BimmerHeads.com
