will any E36 M3 trans fit an E30 ?
  • helalo
    • Oct 2012
    • 93
    will any E36 M3 fit a 325is 88 ?
    within a year i plan to do a S52 swap but for the moment i want to swap the auto trans to something that can handle the S52 and fit in the E30.
    any other transmission would work ? would a 325i trans work with a S52 ?
  • ThatOneEuroE30
    • Dec 2013
    • 8626
    No. You going to need to do a manual swap with all e30 parts getrag 260 clutch pedal and the works. Then when you get a s52 your gonna need to get a ZF tranny and the rest of the stuff to do a s52 swap
    1991 318i 4dr slick top
    Mtech 2 turbo restoration
    • AndrewBird
      The Mad Scientist
      • 11898
      So in other words, just do the S52 swap now. :up:
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        This would be the cheapest cause then you wont be buying two tranny's and two clutches, two drive shafts, two slave cylinders....
        • nyChris
          • Apr 2012
          • 395
          Yes it will. Read the stickies in the 24v section.
          • SmokeE30
            • 1730
            The getreg G260 that would have came in your car works for both your m20 and s52, and is gonna be the cheap easy solution.
            Shawn @ Bimmerbuddies
            Bimmerbuddies LLC
            717-388-1256
            2971a Roundtop Rd, Middletown PA 17057
            bimmerbuddiesllc@gmail.com
            • ThatOneEuroE30
              • Dec 2013
              • 8626
              He has a auto now so he would need to buy a getrag 260 and all the stuff to do a manual swap and then would have to buy another tranny when he swaps
              • mr2peak
                • 2388
                It will. Choose your new diff carefully though. Ratios are different with the E36 M3 trans
                Drive it hard. Maintain it well.
                A Topless Memorandum
                • SmokeE30
                  • 1730
                  The g260 is what his car would have had stock if it were manual. He needs to buy and tranny anyway. And he does not need a different trans when he swaps motors again only a different trans mount crossmember... Like I said it's the cheap easy solution, believe it or not.
                  Bimmerbuddies LLC
                  717-388-1256
                  • B Randon
                    • 2569
                    I have a zf from a 99 m3 i can sell you
                    • ThatOneEuroE30
                      • Dec 2013
                      • 8626
                      I see I have yet to do a 24v swap. I personally would put the zf in either way after I swap the s52 in just cause It's the tranny made for that motor, that's just me though.
                      • cabin
                        • Dec 2006
                        • 552
                        But its not necessary. Plenty of people use the g260 behind their 24v swaps, yet you are telling this guy he needs to buy a different trans when he goes to do his swap.
                        Personal preference is one thing, spreading bad information is another.
                        -Justin
                        Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
                        • Liquidity
                          • May 2014
                          • 395
                          Where did you get this info from?
                          • ThatOneEuroE30
                            • Dec 2013
                            • 8626
                            I had always heard that e36 trans will sit cockeyed on m20's. Looks like I misread some things..... I'm out....
                            • mr2peak
                              • 2388
                              It will. Just like E30 trans will be crooked with an M5x motor. Still works, just not as perfect.
                              ZF with an S5x is preferable to any other combination.
