Half shaft questions (1990 vs 1985)
  • Helltime
    • Sep 2011
    • 96
    I just picked up another e30 (1985 325e 5spd) and the left half shaft is bad, I started looking on pelican and bav, almost $600! My 1990 has a bad right half shaft and it is $350. I would have thought abs would have been more expensive than a non-abs car? Anyone know where I can get a decent rebuilt one or new one for cheaper on the 1985 car? I bought the car for $800 for a winter beater, sure as hell not going to put a $600 haft shaft in it...
    1990 325i 5spd
    09 135i 6spd m-sport package
  • jetavdk
    • Jul 2008
    • 45
    I believe the fitment will not be an issue, the only difference is the toothed ring for the ABS sensor. I recently did a the rear arm swap with discs on my 84 318i and the donor was an 87 vert. I elected to use the 87 shafts on the 318 with no problems.
    Hope this helps,
    Ted
      • 37834
      Correct, the only difference is ABS vs non ABS.
      Check with CAtuned on rebuilt axles. You might like their pricing a bit more.
      Grover Beach, California
      BimmerHeads.com
      • Helltime
        • Sep 2011
        • 96
        Ok, thanks for the info!
        1990 325i 5spd
