2nd gear pop out
  • socalife
    • Jun 2014
    • 177
    2nd gear pop out
    I have a zf trans in my new m50 swap and when I kick the clutch in I get a thumping noise.also, 2nd gear always pops into neutral, and I have a rattle with clutch depressed in neutral
  • efficient
    • Feb 2012
    • 3312
    syncho is done in 2nd
    • DesertBMW
      • Aug 2011
      • 1039
      True
      • jalopi
        • 2370
        Sounds like one of the shift forks is worn out - a bad synchro'll make the trans grind when you try to put it in gear. The forks are what keeps the dog clutch/synchro ring on the selected gear. Pads/fork wears out, you get some slop in the fork and boom the trans can now pop outta gear. Not sure if the ZF has fork pads or if it's one piece, but either way you're gonna need a new (or used) trans.
        • Bullhead
          • Sep 2014
          • 532
          ^ Shift fork or syncro sleeve is worn out, as stated the syncro itself just matches the 2 turning gear sets in the transmission to be able to shift into the desired gear. The forks and sleeves are what hold them in the gear selected.
          sigpic87 325E The Honey Badger
          • socalife
            • Jun 2014
            • 177
            What about the crazy rattle at idle when the engine is cold and in neutral, and the thumping noise when I push the clutch in
            • Bullhead
              • Sep 2014
              • 532
              Throw out bearing, or clutch fork bearing.
              • Poorboyz
                • May 2012
                • 2117
                Google Getrag rattle.
                Rebuilding since 07/06/2016
                Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
                Poorboyz Feedback Thread
                • socalife
                  • Jun 2014
                  • 177
                  But it's a zf
                  • Poorboyz
                    • May 2012
                    • 2117
                    Zf rattle? Lol. Rattling in neutral will not be TOB.
                    Sent from my 831C using Tapatalk
