Hey all I recently did a tranny swap and my old tranny had atf in it but the new one had the green sticker so I put 90wt in it. My local AP store didn't have Redline in stock so I went with Lucas 90wt. Now with these cold days it doesn't shift good till it get's warmed up (like 5 minutes max). When it was warm outside it was fine. It will grind just a tiny bit from 2-3-4 but when it gets warm it completely goes away. Again this has only started in colder weather. Should I have went with something thinner? I have some Syncromax in the garage but it is really thin. I had it for my Getrag in my 3500 Cummins.
Getrag 260 Green Label Fluid Question
Use Redline, order it online and put it in. I won t put anything in my trans. I have 2 extra bottles of Redline at all times.
Sent from my 831C using Tapatalksigpic
Rebuilding since 07/06/2016
Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
Poorboyz Feedback Thread -
Got a link for the oil your referring to bro? I knew I should have got Redline lol. Lucas wasn't cheap but it was on hand.sigpic87 325E The Honey BadgerComment
I've been running Redline MT-90 in mine for almost 2 years. No problems.Estoguy
Need a photographer, come visit my site: http://estoguy.wix.com/unique-perspectivesComment
Gear oil will kill your transmission if it hasn't already. You need to run MTL or MT-90 wich are both GL-4 fluids. GL-5 has a lot of sulfur in it and will eat away at the brass synchros.
Read more here:
Thanks for the info guys. I will get some Redline MTL asap. I also have a case of this stuff http://www.theoilhub.com/Penn_SyncMesh_Flu?src=BingS but no one has said if I could use it or not.sigpic87 325E The Honey BadgerComment
