e36 lsd in e30 open case
  • Need4Speed1299
    • Oct 2007
    • 119
    I just so happen to have a 3.15 e36 lsd diff. I also have an e30 opon differential. Can I take the internals from the e36 and stuff them into the e30 case? Thank you!
  • scobaru
    • Nov 2007
    • 396
    I also want to know
    • TobyB
      • 5243
      Are they both 188mm? Is the E30 diff a low(ish) ratio?
      My second hand recollection is that low ratios (2.73/2.93) will swap for other
      low ratio gears, but when you cross a line (3.07?) the spacing isn't right- the spools
      are different. But that shouldn't matter too much if you change the center...
      No promises here!
      t
      • SkiFree
        • Jun 2011
        • 2766
        Measure the differential width output to output (or if you have the two empty case measure the distance between the side-cover races). If it is the same (or within a couple thousandths) between the e30 open case spindle and the e36 lsd pumpkin the answer is %90 yes.
        Bear in mind you will need to set for correct lash with the different center (plan on getting a couple different side-cover shim thicknesses). You do NOT want to just switch centers and go on your way.
        ADAMS Autosport
        • ibatic1
          • Feb 2018
          • 62
          bumping this because i'm curious and found a lsd out of a e36 at the pick and pull. OP ever figure this out?
