I went to top off my fluids a few days ago and change my oil and I ended up flushing the diff since I think it had the wrong fluid in it when I last topped it off.
When I bought the car, the PO put the wrong fluids in the diff and trans. From what I understand the diff had Castrol Hypoy C 80W-90 Gear Oil and LS modifier added. The transmission, which is a green label w/ external 17mm plugs, had Royal Purple 75w140 Max Gear w/ Friction Modifier.
I initially topped of the diff with the RP 75w140 to address the diff whine. I know the diff has a small leak from the input shaft and thought it was low. The diff whine changed from a constant whine to a whine-warble. I realized that I may have put the wrong fluid in, check the bottles I had labeled when I bought the car, and sure enough the RP bottle was labeled "trans" and the Castrol bottle was labeled "diff".
I went and got Mobil1 75w90 LS diff fluid and drained and refilled the diff and I topped off the trans with the RP 75w140 that I had. I have had the car for about 6 months and have put about 6000 miles on it with those two fluids in the diff/trans and I am worried about what damage could have been caused.
I have the "Green Label" Getrag 260/5 and the diff is a 2.93 LSD. I am currently looking for Redline MT-90 since that is what most people run in this transmission. Apparently the BMW GLS is Mobil SHC630 which is very had to find and 26$ a quart.
My question is this:
1. Do I need to do more than drain and refill the trans with MT-90?
2. Do I need to take it to a shop and pay to have a trans flush? (VIP charges $179 for this service)
3. Is there any potential damage that has been done by running these fluids in the diff/trans for 6000 miles? Is there anything I need to watch out for down the line and should I start saving for a new trans/diff?
4. Is Redline MT-90 what I should be running and is it comparable to the Mobil SHC-630 or do I need to find/order the SHC-630 and bit the bullet on the cost?
