Drive shaft question
  • Steve Corbett
    • Jul 2012
    • 449
    I have an early 08/84 325E I am planning on doing a 5 speed swap on. I have a Early 10/83 528E 5 speed I will be scrapping. It seems several parts are swappable. I am reading that I can just add the manual pedals to my existing auto pedal box? Except I guess the early pedal box does not have provisions for the clutch cylinder mount? Also both cars have transmissions that use Non-Guibo drive shafts. I realize I need a 3 series drive shaft, but have not seen any Non Guibo set ups besides mine.
    Steve Corbett
    1983 528E Scrapped
    1983 528E Sold
    1984 745I
    1984 325E - Sold
    1989 325I Bronzit-Sold
    1989 325I Zinno
    1988 635CSI
    • 37834
    You need to swap the complete pedal assembly. It can be from any non-airbag E30.
    I've never seen a manual trans with the non-guibo style flange. Only auto trans...
    Grover Beach, California
    BimmerHeads.com
    • Steve Corbett
      • Jul 2012
      • 449
      Another question you may have the answer to. I also have a 84 745I, It developed a major leak on the cannon plug on the lower side of the transmission where the wire for the electronic shift solenoids goes. It has a 4HP22 transmission with the dial selector on the console. I was able to find a used section of the wiring. But it was cut just before it enters the floor. Any chance you have a part number for this? I know 5 series had this trans not sure if 3's did.
      Steve Corbett
      1983 528E Scrapped
      1983 528E Sold
      1984 745I
      1984 325E - Sold
      1989 325I Zinno
      1988 635CSI
