Installed a new clutch kit with TOB 5000 miles ago. I took my car out of storage from about 4 months of being stored recently. It's making this weird flywheel chatter noise but it's the stock flywheel. I don't know why, as the car is shifting as smooth as it always has. It especially makes the noise when I downshift and let it engine brake. The pitch changes when I'm in neutral with the clutch in and I put it in first gear and let it rest there (as the video kind of shows). It sounds like a very exaggerated Getrag rattle. Perhaps im low on trans fluid? I know I have had a small little drip for quite some time but I don't know how low trans fluid would make that noise. Any help would be appreciated, thanks!
Weird flywheel chatter noise
Installed a new clutch kit with TOB 5000 miles ago. I took my car out of storage from about 4 months of being stored recently. It's making this weird flywheel chatter noise but it's the stock flywheel. I don't know why, as the car is shifting as smooth as it always has. It especially makes the noise when I downshift and let it engine brake. The pitch changes when I'm in neutral with the clutch in and I put it in first gear and let it rest there (as the video kind of shows). It sounds like a very exaggerated Getrag rattle. Perhaps im low on trans fluid? I know I have had a small little drip for quite some time but I don't know how low trans fluid would make that noise. Any help would be appreciated, thanks!Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Tags: None -
your gears sound quite loud, from what I can hear. Obviously it isn't your flywheel chattering, it is something from the input shaft to the output shaft. (gearbox)
Have you topped off your fluid? I would start there...'84 318i M10B18 147- Safari Beige
Turbo: 221whp/214ftlbs, MS3x flex @ 17psiComment
I have not topped off the fluid, but I will do that.
The reason I don't think its the FW/Clutch/PP is because the noise happens when it's all engaged so that makes sense.Originally posted by TSI♫ Rust flecks are falling on my head...♫OEM+Comment
