Which Brand Center Support Bearing To Buy?
  • GOT8SPD
    • 270
    Ditto as the title says....
    I'm replacing a ton of stuff on my e30, tranny mounts, motor mounts, guibo, etc...after inspecting under the car after taking a bunch of stuff off, I noticed that I'm going to have to replace the CSB as well.
    Since I'm taking the drive shaft out to replace the guibo, I want to go have the drive shaft also rebuilt and balanced as other threads have said that a bad joint in the driveshaft will tear up a CSB just like tranny mounts and motor mounts.
    This job originally was just to replace the guibo, but while I'm there, I want to do the other crap.
    OE BMW Center Support Bearing is $185ish...all the aftermarket ones are MUCH lower in price range...
    $40 for Febi
    $15-$18 for Rein, URO, VAICO...
    I don't want to buy OE BMW if i don't have to, but if that's the best one, then I'll buy it.
    I had issues before buying a cheap chinese wheel bearing for the rear, and it only lasted 6 months. I put in a OE FAG bearing and my problems were solved.
  • SkiFree
    • Jun 2011
    • 2766
    Febi's are great, have been using them after finding the Rein/Uro's fail many many times (their bearing is fine, the rubber is the issue).
    ADAMS Autosport
    • efficient
      • Feb 2012
      • 3312
      Febi +1
      • GOT8SPD
        • 270
        ugh...no one likes cheap rubber...
        • JGood
          • Jan 2004
          • 7959
          Another vote for Febi.
          OE cost is ridiculous, URO quality is ridiculous.
          e30 restoration and V8 swap
          24 Hours of Lemons e30 build
          • GOT8SPD
            • 270
            THANKS GUYS! I'm gonna order a Febi and hopefully drop off my drive shaft to have it rebuilt.
            • JGood
              • Jan 2004
              • 7959
              There's only a few shops that will rebuild e30 drive shafts, your local random driveshaft shop probably won't be able to (at least not correctly). They don't use clips to hold in the u-joints, they are staked/crimped. So although you can disassemble them and install new u-joints, there are no grooves to install the clips that hold them in place, which is what typical driveshaft shops do. Some people have cut grooves so that they can then use clips, but I'm pretty sure that's not recommended.
              You could check out www.driveshaftspecialist.com
              In all honesty, if you don't feel excessive notchiness in the joints, I'd probably just throw the driveshaft back in as-is.
              • GOT8SPD
                • 270
                The joints on my drive shaft SEEMS to not have too much play actually. If the driveshaft joint moves "up and down" and "side to side", it does up and down well, but the side to side movement seems limited? This is the best way I can describe it...
                The center joint seems OK.
                • JGood
                  • Jan 2004
                  • 7959
                  You're not so much looking for play as you are 'notchiness". As you move the joint through it's range of motion, does it get stiffer in a certain area? If there is actual play where you can move the joint in a direction other then what it's supposed to, then no, that's not good either.
                  The driveshaft barely moves at all, so the range of motion isn't important.
