Driveshaft?
  • E46cruiser
    • Jan 2015
    • 9
    Driveshaft?
    So Im almost done with my swap, I used the revshift adapter guibo but it doesn't fit correctly since I have a closed flange and not the recommended open trans output flange. So now I'm looking for a driveshaft. I know it has to be a 96+ 328i or m3 driveshaft. Can it be from either an automatic or manual car? Are the 4 door driveshafts a bit longer, if so could I use an automatic 4 door driveshaft from a 328i? Needs to have a 4 bolt rear correct?
    • 37833
    Does your stock driveshaft have the balancer on it? You can easily remove this without issue.
    If you use an E36 driveshaft it must be manual and 4 bolt rear. Coupe or sedan does not matter.
    Grover Beach, California
    BimmerHeads.com
    • E46cruiser
      • Jan 2015
      • 9
      Not sure what you mean by balancer, but thank you! I wasn't sure if you could use an automatic.
        • 37833
        You said: "but it doesn't fit correctly since I have a closed flange".
        I translated that in to meaning you have a driveshaft with a balancer on it. Post a pic of what you're referring to.
        BimmerHeads.com
